SubUser
Flight distance : 74140 ft
Use an USB keyboard.
See post : "new crystal firmware released".
I know, I should not do that, copy from the link:
The on-screen keyboard has a small bug.
You have a big USB-port on the CS, this is a normal host port for mouse/keyboard.
Put a small/simple USB keyboard on this port, this will work for naming and renaming.
A big gamer-keyboard will maybe draw to must current or need a special driver.
If you want to change a existing file, click on the map-icon upper-right.
If you keep your finger on the file-bar, it will show: delete/rename.
If you click on the ">" you will see the map. |
