KurtVD
Flight distance : 365299 ft
Switzerland
maxheadroom Posted at 2018-6-4 11:14
Its weird as I also fly from the same area all the time. But with the info you gave me the few flights I did was so much better. I will have to try the local field and see how far I can push it. Will keep you posted.
We also lived in Switzerland for a your. Loved it. Based in Dietikon.
Really, you liked living in Dietikon? ;) I guess there must be nice places there as well, but it's definitely one of the less attractive regions in Switzerlands (except economically, of course, I guess you had a job in Zürich or nearby).
As for the transmission problems, if I had at least 500 m of "solid" range every time I went out flying, I would be quite happy, but the problem really is that it's a little bit unpredictable. One day everything's great, the next you can't even take off before the video starts cutting out. At these short distances, it's hard to believe that the weather could have an influence, but I don't know anything about that. What I do know, is that my other drone, the Bebop 2, which also uses WiFi, never has these "bad hair days". I usually have both of them in my car, so I can compare directly, under the exact same conditions. |
