QuadKid
Flight distance : 482349 ft
jake daniel Posted at 2018-5-29 00:27
OK, for sure my mistake was to keep the battery whole day and practically every day in car, and I living in Mauritius where it is hot in summer. I found that frequent sport mode also can cause this and its my case as i fly in windy condition sometimes. Is it true?
Now how to destroy these batteries before throwing it to dustbin, one week salt water, sea water?
Sea water would be the best as it has many minerals/metals dissolved in it, these are the elements that are attracted to the connection and will slowly discharge/short out the battery. Just adding salt to water will do it but will take much longer.
And yes the more aggressive you fly the drone the more draw (Amps) are required thus causing the battery to overheat, if the swelling goes down when the battery has cooled off then nothing to worry about, if it continues to remain swelled up then there is an issue with the cells.
As afr as keeping batteries in your car, I do it all the time, interior car temperatures here in Florida (Summer Time) can easily reach 130-140°F, just keep out of direct sunlight. I have not had any issues due to that. IMO I feel that flying style (Sport) often has caused this issue for you.
