Jumping compass on CS5.5
12Next >
7023 60 2018-5-28
SubUser
Flight distance : 74140 ft
After the last update I have still a compass that is a little bit jumpy on the radar.
On an IOS device it is working perfect.
I did a lot of calibrations, but no luck.
Are there CS devices around where this compass is working better (like the IOS devices) ?
Or I have to wait for a fix from DJI ?
2018-5-28
nixuspix
Flight distance : 2864974 ft
Latvia
I have same problem on 7.85" CS as well
2018-5-28
HedgeTrimmer
Be glad its only ''a little bit jump''.  Only  time mine isn't jumping around is when CS-Ub is setting on solid surface.
2018-5-28
Are you running V02.06.06.00 now? Do you mean the attitude indicator in the APP moves erratically? Did you try to restore the CrystalSky in the factory default to see if the problem persists? If yes, any chance to take a short video so that we could escalate to our engineers for further analysis? Thank you.
2018-6-3
Wachtberger
Flight distance : 261509 ft
DJI Mindy Posted at 2018-6-3 23:19
Dear Mindy, you can see it well on this screenrecording (CS 7.85 HB, latest firmware):
2018-6-4
nixuspix
Latvia
And it not only "jumps" all the time, but indicates different direction compared to the "red" triangle on the right side of screen
2018-6-4
SubUser
Yes, yes.
I already send the short video on another topic.
I also tried other apk-compass software (several).
These does not work, same bad results on the CS.
On my android phone these software does work.
I start to think it is the compass hardware of the CS.
Do you have some kind of usb compass stick to plug-in ?
Regards.
2018-6-4
SubUser
SubUser Posted at 2018-6-4 13:11
Yes, yes.
First the sound of the fan when moving the CS (on mine it is ok), than the jumping of the compass with the map and also with the radar.
On this video it was very bad, on other ocasion it was better, it getting worser when the device is hot and the fan is on (like in this video).
If you got an usb-stick compass and it would solve the problem, I would buy it...
2018-6-4
HedgeTrimmer
nixuspix Posted at 2018-6-4 09:47
Try clicking on the tiny little padlock in corner of box located on the right side of screen that holds map and "red" triangle.
If that does not work.  You will need to rotate your drone, while flying, to match both up.
2018-6-4
nixuspix
Latvia
HedgeTrimmer Posted at 2018-6-4 19:10
Stupid me. Thank You
2018-6-4
Wachtberger Posted at 2018-6-4 07:42
Dear Mindy, you can see it well on this screenrecording (CS 7.85 HB, latest firmware): https://www.youtube.com/watch?time_continue=43&v=xwgaW5wtBoc
Thanks for the video, the issue will be escalated to our engineers for analysis, I will keep you updated.
2018-6-5
Wachtberger
DJI Mindy Posted at 2018-6-5 02:47
Thank you very much Mindy!
2018-6-5
SubUser
Hello Mindy,
Any news from your engineers ?
Regards Sub.
2018-6-18
SubUser Posted at 2018-6-18 13:42
Hello Mindy,
Sub, not yet, I just would like to verify one more thing, did you calibrate the compass in the Settings of CrystalSky? GTScreenshot_20180620_150931.png
2018-6-19
SubUser
DJI Mindy Posted at 2018-6-19 23:09
Sub, not yet, I just would like to verify one more thing, did you calibrate the compass in the Settings of CrystalSky?[view_image]
Hello Mindy,
Yes, I did, following the instructions.
Regards.
2018-6-20
SubUser Posted at 2018-6-20 11:34
Hello Mindy,
OK, I will transfer it to our engineers.
2018-6-24
Sorry to have kept you waiting, per our engineers, it is recommended to update the DJI Go 4 to V4.2.20 to see if the issue persists.
1. While there is an update available for the built-in DJI GO/DJI GO 4 App, you will see a "Download" icon appear as below( CrystalSky needs to be connected to the internet first): 1.png
2. Click "Me" and it will pop up the release note of new DJI GO/DJI GO 4 App.
3. Click "Update" and follow the instructions to upgrade the App to the latest.
4. If it didn't show the "download" icon on "Me", you might go to DJI GO/DJI GO 4 App> "Me"> "Settings" and click "Check for Update", then follow the step 2 and step 3 to upgrade.
2018-7-9
SubUser
DJI Mindy Posted at 2018-7-9 00:21
1. While there is an update available for the built-in DJI GO/DJI GO 4 App, you will see a "Download" icon appear as below( CrystalSky needs to be connected to the internet first):[view_image]
Hello Mindy,
Thanks for your efforts.
I did try to update to version .20 (I am on version .16).
But I got the message back "Lasted version now", I am still on version .16.
I have CS 5.5, is this update not yet on the server, so only for CS 7.8 ?
Regards Subuser.
2018-7-9
Keule
Flight distance : 3733015 ft
SubUser Posted at 2018-7-9 04:26
Hello Mindy,
I have both the 5.5" and the 7.85" - For none of the devices the GO4 update is available. (July 9,2018)
2018-7-9
SubUser
Keule Posted at 2018-7-9 04:50
Thanks for the info.
It is maybe a region issue, Europe the last in the row.
I started a new thread, to see if there is somebody that has more luck.
It would be nice if you could download the file from site and update it from SD card.
And downgrade with the old file if it was not working for you.
Regards.
2018-7-9
Chadizzy
This is not available in USA either. I try everyday still says .16 is the latest version. When can we expect .20 on the crystal sky?
2018-7-9
markiet1966
Flight distance : 1168819 ft
Same for the UK, nothing available yet!
Mark
2018-7-9
Hello Mindy,
DJI Go 4 V4.2.20 do has been released, could you please try again? There should be the upgrade notification when you connect to the network.
2018-7-11
Chadizzy Posted at 2018-7-9 22:00
Could you please connect to the network and try again?
2018-7-11
AnaMar
Estonia
Same situation about jumping compass and update. I have`t update app DJI Go 4 V4.2.20 for CS 7.85" ULTRA (Internet connected)
2018-7-11
Barry Goyette
Flight distance : 14928 ft
DJI Mindy Posted at 2018-7-11 04:56
I'm trying here in the US this morning, and there is no new update (screen reads Version v02.06.06.00 latest version now). "Check for updates" give the same result in CS screen and Go4 screen.
2018-7-11
Barry Goyette Posted at 2018-7-11 07:42
Barry, there is a server glitch at this moment and our engineers are working on it, I will let you know once it is fixed, sorry for the inconvenience caused.
2018-7-12
Chadizzy
DJI Mindy Posted at 2018-7-12 01:11
When did you learn of the server glitch? I have submitted a ticket to DJI support and they said it hasnt been released for the CrystalSky yet.
2018-7-12
nixuspix
Latvia
Chadizzy Posted at 2018-7-12 06:05
[view_image]
Why do You think, that their answer is correct, but Mindy's - not?
I bet its about 50-50
2018-7-12
Chadizzy
nixuspix Posted at 2018-7-12 06:43
I never assumed it was correct. I just asked when they learned of the glitch and pasted the email that was sent to me.  Sounds to me like they need some better communication with their front line support.
2018-7-12
Chadizzy
Same issue.
2018-7-12
Keule
As of now (Jul 12, 2018 - 20:17 hr MEST) the download of GO4 v4.2.20 is working as described above.
2018-7-12
Chadizzy
Keule Posted at 2018-7-12 10:19
Thank you Keule.
2018-7-12
SubUser
Thank you for the info.
Yes, I could also download it and install it.
It is working ok so far I can see, the compass is a little bit better I think.
It is still not an "Ipad" experience...
I will check it tomorrow, it is already dark here, we may not fly in the dark over here.
I found a new option: if you do a factory reset, it will go back to the previous version .16.
Maybe I was "lucky", maybe you can now always go back to the previous version or at least for a test-period. So I had to install the update again.
Mindy : DJI should communicate better to us about the things you build in and the fixes you do. Do we have a rollback option in the factory-reset ?
Regards SubUser
2018-7-12
[view_image]
Chadizzy, the server glitch has been fixed, there is the new DJI Go 4 available, please have a try.
2018-7-13
Chadizzy
DJI Mindy Posted at 2018-7-13 03:25
I was able to update thank you so much!
2018-7-13
SubUser
Hello Mindy,
I did some more tests on the compass.
Recalibration, etc, etc.
It is still bad, I cannot use it for anything.
Did your engineers do something on this issue or did they work on something else ?
Regards Subuser.
2018-7-13
SubUser Posted at 2018-7-13 12:32
Hello Mindy,
Subuser, you are right, since the DJI Go 4 are updated separately, once you restore the settings to the factory default, the APP will be downgraded to the previous version.
Sorry to know the compass still doesn't work, I will let our engineers know.
2018-7-14
SubUser
DJI Mindy Posted at 2018-7-14 01:14
Hello Mindy,
About the compass :
I did find out that the compass does works better if you keep the monitor horizontal.
So, if I want to know the orientation of the drone I keep CS for a moment horizontal (flat).
It works for me.
In the calibration, the second part, the vertical calibration is not working properly.
Maybe this will give some clues for your engineers.
Regards.
2018-7-15
HedgeTrimmer
SubUser Posted at 2018-7-15 07:06
Hello Mindy,
About the compass :
Saw that about 10-minutes ago, when calibrating compass of Cs-Ub.
Plan to try Re-calibrating both Cs-Ub and MPP in different area.  That I know has zilch for sources of magnetic field interference.
2018-7-16
12Next >
