SubUser
Flight distance : 74140 ft
Wachtberger Posted at 2018-7-24 13:01
When I fly with my tablet, the position of aircraft is shown correctly at all times and my tablet has no compass. Therefore I believe that the inbuilt compass of CS is not really needed, or am I wrong?
Hello Wachtberger,
If your looking at the maps, you get a fixed north.
So you see the position of the drone = information of the drone.
If you unfix it, it will change the map in the proper direction, so you get the position of the drone relative to you.
The small radar works in the same way like the unfixed map. = information of the drone and information of you tablet together.
Yes, to get to work this you need a kind of direction system inside the tablet.
This could be a magnetic sensor or a GPS/gsm-points in combination with a acceleration sensor.
So far I know an Ipad uses all these sensors together to get a smooth reliable direction system.
Regards |
