RobSkyHigh
Flight distance : 1640 ft
QuadKid Posted at 2018-5-29 04:42
Great job Rob, beautiful countryside. Quick question, when you are doing a hyperlapse are you simply flying the drone and taking stills at an interval setting? Or do you use waypoints (Go4 and/or Litchi) and fly the mission taking stills? I have attempted to due hyperlapse, this one is me manually flying in tripod mode while app takes stills at 2 second interval, had to stabilize the video 3 times over to even get it close to usable still has some stutter, the jerky effect closer to the end is from me adjusting the yaw (will avoid doing that in the future). What's you trick to get smooth video with hyperlapse motion embedded?
1st attempt at hyperlapse
Hey QuadKid,
My technique is very similar to yours with just a couple of differences. I put my Mavic Pro in Tripod mode and either hold the stick all the way forward or to the side. I seldom do anything else with yaw or the gimble. Instead of using the auto interval, I do it manually because I want a faster interval than auto will allow. Even in RAW I can manually click the shutter once every second or maybe even a little faster. This gives you more information for when you stabilize later. I click the shutter button on the right side with the same hand that is holding the stick(not the virtual button on the screen, but the physical one on top of the controller.)
Obviously the less wind the better but I've also noticed that it really helps to keep a high altitude. The closer you are to land, the more difficult to stabilize effectively. I compile my stills in After Effects and use Warp stabilizer and play with it until I'm happy. I also use Neat noise reduction and a deflicker program. Hope that helps! |
