new DJI GO full screen via sgs 8
1360 15 2018-5-29
desel
Czechia
Hello
i have a problem with new DJI go 4.2.16. I am using Samsung galaxy 8 and
on old version DJI GO i had full screen live view on screen, but after upgrade on DJI GO 4.2.16 i did not foud way how to
set full screen like old DJI GO
i have set ratio 16:9 in DJI GO.
do you have any idea ? i did not found anything on forum
before update on new DJI GO
Afetr update DJI GO
Afetr update DJI GO
2018-5-29
LeafPeeper
Flight distance : 450075 ft
You're in picture mode and 4:3 aspect ratio.   Slide the little camera icon to movie...
LP
2018-5-29
desel
Czechia
LeafPeeper Posted at 2018-5-29 03:46
LP
but i use aspect ratio 16:9.
If i used 4:3 the picture was even smaller.
pictures is not my but it the same like in my case
2018-5-29
G_Sig
Flight distance : 9109311 ft
Iceland
desel Posted at 2018-5-29 03:51
Don't swipe down with one or two fingers not work?
2018-5-29
desel
Czechia
G_Sig Posted at 2018-5-29 03:58
if i use fullscreen via finger, ratio is the same so not work.
I reinstaled GJI Go but nothing happend.
i expected problems when i bought mavic (because galaxy s8 has a diferent ratio 18:9)
but it works until DJI GO 4.2.16
2018-5-29
G_Sig
Iceland
desel Posted at 2018-5-29 04:56
What is your display settings?
2018-5-29
desel
Czechia
G_Sig Posted at 2018-5-29 05:26
[view_image]
i have a FHD+ 2220x1080 resolution
2018-5-29
G_Sig
Iceland
desel Posted at 2018-5-29 06:19
Yes I don't use that, don't remember why.
2018-5-29
G_Sig
Iceland
Sorry it's WQHD 2560 x 1440 which I don't use.
2018-5-29
LeafPeeper
Let's try this again.   When you are in PHOTO mode, that's exactly what mine shows because it takes the pic in 4:3 aspect ratio to use the full sensor 12MP.   If I switch to MOVIE mode, then I get get the 16:9 full screen image.   Did you switch to MOVIE mode?   What happened?
LP
2018-5-29
desel
Czechia
LeafPeeper Posted at 2018-5-29 16:23
LP
thank you for your answer i will try at home today.
2018-5-29
desel
Czechia
desel Posted at 2018-5-29 22:13
i switched movie mode without any changes.
i will try refresh firmware
2018-5-30
LeafPeeper
Interesting....Ok good luck.  Strange situation!   Let us know how you make out.
LP
2018-6-1
G_Sig
Iceland
LP
Photo mode can bee both 4:3 or 16:9 you select it in settings.
2018-6-1
desel
Czechia
I refresh firmware and reset factory default without change.
I instaled old DJI GO 4.2.14 so i tested today
2018-6-4
desel
Czechia
desel Posted at 2018-6-4 04:32
I installed dji go 4.2.14 and 4.2.12 and it working on full screen, so it must be a problem in 4.2.16.
2018-6-4
