Dji Matrice 210 power out connector cable
3817 2 2018-5-29
fans9f1e87ac
Flight distance : 163287 ft
Puerto Rico
Hi everyone,
Does one of you know what type of connector I should use on the Dji Matrice 210 power out.
Thanks,
Omar
2018-5-29
Do you mean the Extended Power Port on the right side? If yes, this is a standard XT30 port, its voltage range is from 18V to 16V with a current of 2A, you will just need to make sure your device is satisfied with the voltage and current requirement.
2018-5-31
Léo STUDIOFLY
Flight distance : 1783087 ft
Is it possible to find a cable for the XT30 port to an USB-C output ? Sorry to ask 4 years later
2022-9-22
