HedgeTrimmer
I'm not familiar with assistant 2. How do I get it and use it?
Look below for Assistant 2 download locations
Mavic Pro - https://www.dji.com/mavic/info#downloads
Mavic Air - https://www.dji.com/mavic-air/info#downloads
Make sure you download correct version (Zip / Exe for Windows) (DMG for Macs).
As for using. You will need a USB cable that will connect to your drone and to your computer.
Installing Assistant 2, may not go smoothly. There can be issues with both Windows and OS X flag install packages as from an unsigned or untrusted source.
On Mac, simply double-clicking on Install package (DMG) will not work. You have to click on Install package file, then open it with OS X installer.
As part of Install of Assistant 2, you will have to select what personal / drone data DJI has access to.
After getting Assistant 2 installed, you need to connect USB cable to your drone, power-up your drone, start Assistant 2, then connect USB cable to computer.
Under Assistant 2 you will have to Login like you do here.
From there, you will have to select your drone on a new screen, after which screen will change showing list of things that Assistant 2 can do.
Pick-out Firmware, and new window will open showing current firmware, previous firmware, and possibly new firmware.
