Phantom 3 advanced stops recording every 8-30 seconds?
4507 17 2015-5-13
cameronlevine
The title says it all. I can record video for up to 30 seconds it seems and then I get a blured line and the video stops. Does anyone have any ideas? The 24-7 tech support was useless.
Update: Just spoke with the LA office. They didnt try to trouble shoot my situation or give me any suggestions to try. They just said send in the phantom and expect a 7 week turn around from when they get it. There goes my summer with the phantom.
2015-5-13
jwhite
Most likely your card is not fast enough to record the file sizes (I'm guessing you bought a different card than what came with it right?). This is usually the common answer when it comes to this with DSLR's.
2015-5-13
cameronlevine
jwhite@schillin Posted at 2015-5-14 05:38
Most likely your card is not fast enough to record the file sizes (I'm guessing you bought a differe ...
Nope im using the 16 GB card that came with my phantom. I wish that was the solution bc that would be a quick fix
2015-5-13
Jon.hopkins.1
I haven't had a problem like this, format the card, re-install the app are my suggestions
2015-5-13
jasontcheney
I just had this happen to me over the weekend. I hit record and 15 seconds in It randomly stopped, I didn't notice for 45 seconds. Then I hit record again and after 30 seconds it stopped again. I have the Phantom Advanced as well, 16gb card that came with it.
2015-6-15
nspusmc
I am also having this issue on the P3 Advanced. I have not yet tried to reformat hard drive etc. I will try tomorrow
2015-7-10
robrogkr
Flight distance : 293976 ft
Poland
I suppose you have this problem with MP4 file, correct?
Verify whether it is the same of recording in a MOV file.
2015-7-10
karel.spulka
Czechia
Have the same issue, sometimes its working well, sometimes (like now) Iam not able to do a proper video. But yeah, Iam using mp4, going to change it to move, lets see...
2016-4-5
pgrover516
Banned
2016-4-5
karel.spulka
Czechia
So, yeah, I deleted all the videos, turned to mov and the problem is gone, at least I hope so. By me it didnt happened always, but just sometimes, lets see after a few flights
2016-4-5
Razgriz1
Flight distance : 181322 ft
karel.spulka Posted at 2016-4-5 11:03
Did changing the format do the trick? I've tried two different memory cards now and they are both doing the same thing. The latest one is a Samsung Evo 64GB U3. Tried recording both at 2.7k and 1080p and it kept doing the same thing.
2018-10-20
KenDuke
Flight distance : 50837 ft
Format the card on your computer first.  Then, stick it in the gimbal, and turn the phantom on.  You should get a error message saying the card needs to be formatted in DJI GO.  Format the card again now.
And, then do it 1 more time.
I've yet to have this issue, and I have a P3A.   My micro SD card is a Samsung 64 EVO XC1.
2018-10-20
Geebax
KenDuke Posted at 2018-10-20 14:52
Formatting rthe card in a PC does not do the job any better than performing a format in the aircraft. Using the aircraft has one advantage though, it knows what format to use. The issue here is most likely that the card is filling up with lots of hidden files that DJI create, and the OP has been copying and deleting files on the card, not knowing about the presence of the hidden files. Formatting clears ALL files off the card.
2018-10-20
KenDuke
That could be as well.. But, formatting the card on a PC will quickly check the card for errors, and mark them.  Its one of the main reasons I do that.  Once the card is stuck in the AC gimbal, since its in the wrong format, the AC will request to format.  All marked bad sectors will be left alone, and only the good will be marked as usable.
2018-10-21
Razgriz1
I think I figured out what it was for me. I noticed a lot of junk files on the card before I formatted it. Being the cheap person I am, I had been swapping the card in and out of devices constantly, between the phone I use to shoot video, my DSLR, and my Phantom 3. Tons of junk on the card including Android data files and such. As soon as I formatted the card and stopped swapping it between devices, I've been able to record in MP4 at 2.7 without any stops.
I guess I have a new dedicated SD card for my Phantom! Thanks for everyone's input!
2018-10-24
Geebax
Razgriz1 Posted at 2018-10-24 06:46
You have learned an unfortunate lesson, do not put the card into other cameras. This is a known issue.
2018-10-24
Paputzaa
Flight distance : 8645 ft
Thailand
Geebax Posted at 2018-10-24 14:47
I also had similar problem, suggest to use proper speed or better SD Card such as U3 or class 10 and do not use cheap, unbranded  or fake SD Card.
2018-10-25
Razgriz1
Paputzaa Posted at 2018-10-25 01:43
The card in question was a Samsung U3, but it was indeed because of swapping it between devices that did it to me. Lesson learned! I'm just happy to be flying/recording again!
2018-10-25
