paul2660
Flight distance : 10331 ft
This is a note to DJI.
Currently, the pano mode on the P4 Pro and P4 Pro Vr 2.0, is taking the gimbal to the max height and thus pulling in props into each top shot.
So for example on the 9 shot horizontal the top 3 frames have taken the gimbal to the max height even with the 30% up gimbal feature turned off. Thus the pano feature is over-riding the gimbal up feature.
Most of the time this involves sky, as it's up, but it does add more work to the image process as you really need to take the props out of the image before you stitch, and thus it makes it next to impossible to stitch from raw/dng, which is preferable.
In the future, would it possible to make a setting for the pano software for the P4 that will limit the up on the gimbal to around 15%? This would be a great addtion to the software and save a ton of time in post.
It would also be a nice feature to add to the P5 or follow on to the P4, the ability to rotate the sensor to the portrait view like in the Mavic.
Sincerely
Paul Caldwell
www.photosofarkansas.com
