hallmark007
Flight distance : 9812789 ft
Sweden
Just on that point, although it seems now like your trolling, in your up to date safety and disclaimers for Mavic Pro , it clearly tells you NOT TO CALIBRATE UNLESS PROMPTED, but aside from that.
Phantom , only calibrate when prompted
Inspire 2, only calibrate when prompted
Spark , only calibrate when prompted
Mavic Pro changed in manual to calibrate every 10km
Mavic Air calibrate if moved more than 50km
In all of above safety and disclaimers manual (probably your most important Manual) ONLY CALIBRATE WHEN PROMPTED.
I’m sure you are aware what disclaimer means but just to refresh , if you don’t adhere to this then your warranty is in danger of of being null and void.
So information I gave was correct at the time I put up both thread and post, administration here thought that it was good information and decided to put it up as a sticky.
I still stand over what I said, and I believe that most users calibrate their compass when prompted. |
