rocejo
Here's my issue. I will try to be as descriptive as possible. Please feel free to comment as I am trying to figure out what's wrong with this issue.
I own a Phantom 3 Advance Model.
Upon receiving the Phantom 3, I upgraded both the Aircraft and the controller to the latest firmware of 1.1.8.
I checked the .txt file upon updating both the Aircraft and controller and both said "Success" within the .txt file. Thus, indicating a successful update.
I'm using an iPad Mini 2 Wifi and iPhone 6+ (Both Supported Models). Both iOS devices are running iOS Firmware 8.3. This is the latest firmware available by Apple.
I downloaded the latest Pilot App via the Apple App Store. This is version 1.1.1. which states is compatible with Phantom 3 and iOS Devices.
Here's the process. I connect the iPad Mini or iPhone 6+ via USB cable to the controller. I open the application. I turn on the controller and then the aircraft. Upom turning on the controller I am requested by my device to "Trust" the application. I select "Trust". Shortly thereafter, There is a loop where every 10-12 seconds aI am agTrust" the same prompt comes up again asking me to "Trust or Don't Trust" device. Therefore, a connection is never established and the Pilot App never connects to the aircraft. Thus, I am grounded and unable to fly.
Couple of things I wanted to point out. I've done a fresh restore on both the iPad Mini and iPhone 6 + where I manually restored both devices to a clean start running iOS Firmware 8.3. I've used a total of 3 seperate USB sync cables for my Apple devices. All cables are original in nature and not aftermarket.
I've attempted to re-install the firmware on the aircraft and the controller. Respectively, I get the following message in the .txt file upon updating.
"The firmware on the SD card is identical to or older than the current firmware on the aircraft"
and
"The firmware on the SD card is identical to or older than the current firmware on the remote controller"
Lastly, I've deleted and re-installed the DJI Pilot App several times and have the same result.
I need help, I've contacted DJI and they have indicated they will notify their R&D team and get back to me.
Is anyone else having this problem??
