stable walkarounds needed
540 4 2018-5-31
Hifi
Flight distance : 510810 ft
I've used an Osmo mobile 2 with an iPhone 7 and Filmic Pro. Now I've purchased an Osmo Pro with Zenmuse X5 for better quality and more flexibility, I expect delivery in the next days.
My job is video walkarounds in low light situations indoor. The movies with iPhone+mobile2 are not stable enough.
Is the Osmo Pro more stable than Osmo mobile ? Or do you reccomend the z-axis attachment?
The next job must be stable, I have no time to check, test and try out before. If recommended, I will order z-axis too. Or are special plugins or worarounds in postproduction the solution? I am using Final Cut Pro X.
Thanks in advance.
2018-5-31
Hifi
edit: workarounds
2018-5-31
DJI Tony
Actually, the Osmo Pro is more stable than Osmo mobile 2 since you don't need to look for a perfect position to balance your phone, because the gimbal and camera already balanced and yes you can add the z-axis on your Osmo pro for you to have smooth film, however, it's not intended to use in some sports or actions that involve extream movements.
2018-5-31
Hifi
DJI Tony Posted at 2018-5-31 08:59
I do not intend to do extreme movements, just walking. I hate the up and down while walking.
2018-5-31
Matthew Dobrski
Flight distance : 1831050 ft
Hifi Posted at 2018-5-31 11:33
Z-axis attachment may help a bit, but in general you're expecting a miracle to happen. Every professional cameraman must employ so-called Ninja Walk to avoid excessive ups and downs. DJI Z-axis will bounce back badly every few steps if not dampened by hand. No matter what be prepared for some practicing...
2018-6-4
