fanseb52401b
Flight distance : 708658 ft
Bulgaria
Hi all. I purchased the Ocusync Air Unit + DJI Goggles RE combo. I have setup everything and it seems to working fine. I only have problems with the head tracking.
As it seems I need to connect my Head Tracking gimbal/servos through to the dedicated port on the air unit. This poses a lot of problems.
1. The signal output is PPM, so I need a PPM to PWM.
2. Increases overall cost unnecessarily.
2. Considering the short camera cable and all other components already make it hard enough to mount it on a plane, so adding PPM to PWM makes everything even worse.
The SBUS is capable of outputting more than enough channels, so adding 2 or 3 channels for Head Tracking to it would be perfect as it is not a problem for most flight controllers to just relay a certain channel to a given servo which could serve as Head Tracking system on the aircraft.
Please add the option to output the head tracking through the SBUS port, ideally allowing to select on which channels.
That would make it even better product.
Thanks!
