hallmark007
Flight distance : 9812789 ft
Sweden
djiuser_9aD0xZzNlIwx Posted at 2018-6-1 22:19
Sounds right but is this normal? The drone was sitting there hovering for 2 and a half minutes. Thank God there was enough battery left to come home. What if the battery wasn't enough?
As wacthberger said loosing video signal won’t initiate RTH, and if you lose RC signal it will start RTH after 3 seconds and if signal returns within 3 seconds then RTH won’t initiate, and to answer other queries it will continue the same practice as long as you let it or until it gets to low battery, it is explained very well in your manual.
You must also check that you don’t have loss of RC signal set to hover, this is only for VLOS , make sure you have it set to RTH. |
