Oldmaninwva
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
Flight distance : 9750253 ft
fansd1c799cc Posted at 2018-6-2 11:17
the battery is almost full day on the charger and still unchanged. the battery was about 12 hours on the charger that is in the photo and now is charging via USB for about 8 hours. also unchanged. the battery is definitely the original though it may look different in the photo. I have heard about some formatting of the battery, but I think that it is necessary to turn on the battery and put on the spark. the battery is almost full day on the charger and still unchanged. the battery was about 12 hours on the charger that is in the photo and is charging via USB for about 8 hours. also unchanged. the battery is definitely the original though it may look different in the photo. I have heard about some formatting of the battery, but I think that it is necessary to turn on the battery and deploy it. so I'm trying to find a solution in this way because there can be someone who has the same problem and maybe successfully solved. so I'm trying to find a solution in this way because there can be someone who has the same problem and maybe successfully solved.
"Formatting" the battery???? Never heard of that before. From the pics you posted and what you're saying about what the battery is NOT doing it appears that you have a BAD battery, I would suggest that you contact DJI customer support, that is IF you bought a "Real" DJI battery, new, thru a retailer. |
