Ipad 9.7 (2018) 6th gen WIFI weak transmission
2255 8 2018-6-2
bernardren07
Flight distance : 48504 ft
Singapore
Hello. Most i used android note 8 and xiaomi mi 5 plus without any weak transmission. I bought new ipad 9.7 (2018) 6th gen WIFI. I got worst weak transmission. Anyone can teach me how to fix it? It my first time used ipad 9.7 (2018). My phantom 4 pro version 01.04.0602 without any updated since i bought it and DJI GO 4 APP 4.2.16. Help me and teach me. Thank you very much
2018-6-2
bernardren07
Singapore
To think i should read more about 2.4ghz and 5.8ghz. My current is 5.8ghz. outside alot of houses with high wifi.
2018-6-2
DJI Natalia
Please see the attached pdf file. Thank you.
Phantom Solution to No Image Transmission Signal EN.pdf
5.74 MB, Down times: 13
2018-6-4
bernardren07
Singapore
DJI Natalia Posted at 2018-6-4 12:40
Hi. i cannot see pdf. can send me again
2018-6-4
Bashy
Flight distance : 2354357 ft
bernardren07 Posted at 2018-6-4 19:38
Just try it again, sometimes not work 1st go
2018-6-4
bernardren07
Singapore
I got open pdf. My guess if house height is 20 to 30m. drone need to high 70 to 100m to avoid wifi jam. flew to forest no problem. Now i understand already. thank you so much
2018-6-4
Antonio76
Flight distance : 144403 ft
Denmark
The tablet has nothing to do with the wifi signal. All transmissions take place between the drone and the remote control, and the tablet or phone does not need to be on wifi.
2018-6-5
bernardren07
Singapore
I dont know how to explain. My english so so. LOL. I will send youtube later. Flew forward to area of houses had weak image transmission and disconnected and pop up no gps short distance when i was stood and showed satellite 19. Last few month ago i helped my friends wedding. i used it and flew area of house no problem and fine but now i saw app update 4.2.16 so i updated it and tried to flew there but weak. I tried to downgrade app still no luck. Flew to area of house weak image but flew to forest good. p4p version 01.04.0602. Check compass little low. Now i decide to update firmware 01.05.0600 and saw compass all higher green. I will test it later.
2018-6-5
DJI Natalia
bernardren07 Posted at 2018-6-4 20:16
Great to hear that, Sir. Enjoy flying!
2018-6-5
