ruggbg
Mark The Droner Posted at 2018-6-2 11:51
Usually after a crash as you described, either the motor(s) burn up or the ESC burns up. Hard to tell which. I would inspect everything again at home. Then see if it boots up normally. If it does, then try it again at home on the bench, and if they still don't start, begin replacing the motors. If they don't run, you'd need a new centerboard most likely.
Next time, I would pick the phantom up firmly by the landing gear with one hand, hold it upright and steady, and then pull the left stick down and hold. The motors should stop after 3 secs.
thanks mark
I did pick it up by the landing gear - which is why I said it couldn't pick me up.........
I tried everything to stop it, left control, switches. powering off the battery - which appeared to turn off then right back on but the props never stopped.
The motors did spin up the first time I tried it without the props, but are dead now. Nothing on the board looks overheated, especially not the N03Rs. I would doubt all 4 motors went bad at the same time. |
