Mark The Droner
Flight distance : 2917 ft
When you lose the FPV signal, it will give you a message on the screen that says DISCONNECTED. But what's likely is only the FPV signal is disconnected. Your control signal is likely still connected, so RTH won't necessarily happen - at least not right away. So it would be wise to manually invoke RTH, and you might consider turning your controller off to ensure RTH. Turn it back on after 10 secs pr so.
Re parabolics, if the one you find is tuned correctly, it may help with the control signal, but it won't do anything for the FPV because those antennas are patch antennas hidden inside the controller. And since the FPV generally goes out first anyway, I'm not sure you are going to need more distance for the control signal. You'd be flying blind. And besides, it will do nothing to solve your problem as described in the OP. Good luck
