Mirek6
Flight distance : 609724 ft
Regarding "Position hold" video earlier in this thread.
For those who would like to understand a bit better why, when you do not touch the sticks the AC returns to the same position even if you drag it by force to some other place, but, the moment you touch the sticks it "forgets" its previous co-ordinates.
AC keeps track of two positions: Commanded position and Physical position. Commanded position is where, it thinks, you asked it to be (by using your stick movements and compass) and Physical position is where it really is (using GPS co-ordinates). When you put your AC in hover over particular point in GPS mode, you "commanded" it to this spot and it flew there and confirmed that his physical position agrees with you commanded position. If it is not quite right, it will adjust it - this is what you see in the video when drone is "hunting" for a correct position. In the end its commanded position = physical position and it will stay put.
When you drag your drone out of its hover position (by catching it and physically moving to different spot while it is still flying) without touching your sticks, your are not changing Commanded position but you are changing Physical position. The drone will start to fight with you and pull in the direction of the Commanded position (which did not change). As soon as you release it, it will fly to the Commanded position.
However, when you drag your drone and than move your sticks slightly, the Commanded position gets recalculated based on where you are at this particular moment and what you did with sticks. If the movement is very slight, the new commanded position is almost in the spot where you are with your "fighting to fly" drone. Your drone immediately recalculates that its physical position now equals commanded position and stays in place.
This is what we witnessed in that video. |
