SubUser
Flight distance : 74140 ft
pmshop Posted at 2018-6-6 08:14
I guess I am not understanding...
Why wouldn't the DJI GO 4 app not limit the distance/ altitude for iOS 12 as on iOS 11.4?
If you connecting systems together, you must see it as one system.
So your Spark, remote controller and phone act as one system.
The distance/altitude limit is an active safety, there is a active program that says : hey your over the limit, you should stop now, to the other part of the system.
A brick wall is a passive safety. Whatever, if you fly against the brick wall it will stop your Spark.
If your software is does do something wrong, for example sending in a loop : go 100% speed forward and crashing the software safety monitor in the Spark. You will have a problem.
So it not the limits that is different, it is the stability of the software of whole system that could cause big problems. A part of this forum reports is about this.
Beta is beta, it sounds like "bad" in plural.
