EdisonW1979
Flight distance : 1535679 ft
The Otter Posted at 2018-7-6 02:52
DJI support asked me to fill a RMA return sheet, to probably send the drone back. Has anyone done it and had success with a new (or fixed) drone ? I'm kinda scared to send it back for nothing, or worse, get new issues not software related... Or even send it back, and while it's at the support center, miss a FW update that could solve the issues...
I'm left with the random drifting / yawning since FW 0.0400, and very bad video quality / lag that a lot of people are getting anyway (that seems to be DJI GO related).
I would say don't bother with sending your MA back, it's likely the replacement you'll receive will have similar issues, if not immediately, after a certain amount of flights / flight time.
As I wrote in this and other threads, I went to a local Apple Store to pick up another MA for testing, as I could return it hassle-free within 15 days, and sure enough, at about my 4th or 5th flight if memory serves, the second unit began experiencing yaw / drift issues, and sudden yaw turns at random.
And others here have also said, even if you re-flash the drone with Assistant 2 1.2.4 in full, and them perform the gauntlet of re-calibrations, it seems to work OK at first and then the problems return after time, though some have said it solved their issues permanently.
And yes, the video quality / signal range issues are due to bad code introduced to the DJI GO 4 app seemingly around v4.2.16 or so, and DJI has acknowledged this in another thread, but thus far continue to fail to release a fix for it, 3 builds on.
And the issue seems FAR more pronounced for Android users than iOS, if the massively negative feedback being left on the Google Play Store is any indication:
https://play.google.com/store/apps/details?id=dji.go.v4 |
