I have an M210RTK
Today I calibrated the vision positioning after it told me to.
Now I get the error “Incorrect Battery Position. Re-attach all batteries” and it won’t fly
All firmware current
All batteries 5 sets- gives me the same error
EHardesty, may I know if the issue persists? If yes, please double check the battery slot, you can try to clean the pin with the ethyl alcohol until it dry, then try again.
Make sure you really slam the batteries in with assured click of locking mechanism. If that doesn't solve the issue with all batteries, only service may help.
Same problem here. I own a Matrice 200 v1. And I´ve found other M200 owners that have been trough the same issue. It seem to be a faulty engineering project. Because the internal battery compartment inner pressure spring seems to broke after some time of use. In my case the left one broked and now the battery don't lock anymore and the dji go don't turn on the motors. Now I don't what to do, because the repair cost in Brazil is very high.
