CrystalSky and Spark
2177 20 2018-6-5
ToscanaDrone
Flight distance : 13833304 ft
Hello
I purchased the CS 7,85" to use it with the Inspire 2. I also have a Spark and I bought the DJI adapter for the radio control and the OTG cable, but Spark does not connect OTG to CS, wi-fi only (with the iPhone and OTG cable works perfectly).
Both Spark and CS are updated to the last firmware.
Any idea?
2018-6-5
nixuspix
Flight distance : 2864974 ft
Latvia
I am using CS 5.5" with Spark and with latest updates OTG works very reliable
2018-6-6
ToscanaDrone
nixuspix Posted at 2018-6-6 00:53
Maybe some differences between 7,85 and 5,5?
2018-6-6
Taz Flyer
Flight distance : 161588 ft
Hello, I use my Spark with my CS 7.85 (WiFi) and the Spark remote controller,  it works Great. You might want to get a good bracket for the Spark remote controller to hold your CS.
This is the one I use.  https://www.polarprofilters.com/products/crystalsky-mavic-mount
2018-6-6
ToscanaDrone
Taz Flyer Posted at 2018-6-6 15:35
...I use the original DJI bracket!
2018-6-6
fansa017bfa8
Flight distance : 175492 ft
ToscanaDrone Posted at 2018-6-6 23:34
Crystal Sky 5.5/ DJI mount works well with my Spark via OTG. Only thing I don't like is you have to plug the OTG cable into the TX after it connects to the Spark.
2018-6-7
ToscanaDrone
fansa017bfa8 Posted at 2018-6-7 06:56
So, start the remote, start the Spark, wait connection then plug the CS cable to the remote?
2018-6-7
nixuspix
Latvia
Exactly, OTG is first plugged to CS and then after connection between RC and AC is established, you plug in the other end of OTG to RC
2018-6-7
ToscanaDrone
Works!!!
Thanks!
2018-6-7
fansa017bfa8
On my P4 I mount the  crystal sky to the TX and turn it on. The crystal sky turns on automatically and boots up.  it is very awkward to plug the cable in with the Crystal mounted  on the DJI mount.
2018-6-7
Wachtberger
Flight distance : 261509 ft
When I still had the Spark my 7.85 CS was connected via OTG cable to the RC before switching anything on. Then only switched on the RC and the CS automatically started as well.
2018-6-9
SubUser
Flight distance : 74140 ft
Wachtberger Posted at 2018-6-9 04:51
Maybe in the past.
It does not work on my Spark.
First I connect the cable on the CS (usb c) and switch on the RC.
Wait for the red led of the RC is not flashing but constant on, or a constant green led (the Spark is also on and connected).
Then I connect the otg cable on the RC.
The CS will automatic power on and goes directly to the GO4 app.
Now the big surprise :
If you power down the CS, it's restarts again!!!
You have first to power down the RC or disconnect the cable, before you can powerdown the CS.
2018-6-9
nixuspix
Latvia
SubUser Posted at 2018-6-9 17:55
Maybe in the past.
" Now the big surprise.."
Any Android device automatically powers up, when you connect charging cable - so no surprise for me
2018-6-9
SubUser
nixuspix Posted at 2018-6-9 22:26
Not my Android Samsung A5 2016 Phone.
It is only showing the battery charging picture for a moment, it does not startup.
Does your device restart itself when it is charging and you power it down again ?
That I was talking about.
When you connect the CS and RC together in power down state.
And power up the RC (Spark controller), the CS does not startup.
Maybe it does work with your RC - Mavic Air contoller.
This is always the problem: different situations, different results.
Regards.
2018-6-9
nixuspix
Latvia
SubUser Posted at 2018-6-9 23:36
Good to know that not all devices behaves same way. Thank You for example. Yes mine restarts
2018-6-10
DJI Diana
Flight distance : 2408 ft
Hi, sorry for the late response, glad to know that you have solved the problem, hope everything is fine. If there is any further issue, please feel free to let us know.
2018-6-10
DJI Thor
Flight distance : 13602 ft
In fact, it is suggested to connect the Crystalsky and Spark via WiFi. Thanks for your attention.
2018-6-10
SubUser
DJI Thor Posted at 2018-6-10 21:27
Yes, we know.
It is not working well in Europe due to the CE norms.
We prefer here to fly with the cable.
Maybe you could release a new RC for the Spark like the Mavic Air with the normal USB connector.
Or an universal RC for the Spark and Mavic's: a little bit bigger, a CS mount and with better antenna.
Regards
2018-6-11
DJI Thor
SubUser Posted at 2018-6-11 09:02
Yes, we know.
I had forwarded the requirement of officially support OTG to the engineers. And the engineers are also aware of this. If it is confirmed fully supported, we will let you know. Thank you very much for your understanding.
2018-6-11
SubUser
DJI Thor Posted at 2018-6-11 20:03
Thanks for your response.
We look forward to your confirmation.
Regards.
2018-6-12
DJI Diana
SubUser Posted at 2018-6-12 09:27
You're welcome. If there is an update about it, we'll let you know at the first moment. Appreciate your support to DJI products.
2018-6-12
