Mavic's batteries sometimes takes to long to recharge.
865 16 2018-6-6
fanseefdd4c6
Hi,
Usually for recharcing I've seen that it takes 1.10 h, but sometime it takes much longer, more two hours, even three.  I have three batteries and it seems to do with all all them. It could be a problem with the recharger?
2018-6-6
Ex Machina
Flight distance : 1806362 ft
Assuming you are not talking about the car charger, with which the car has to be running for the charger to get enough juice to do its thing, yes, it could be your charger -- I've never seen it take that long to charge any of my three batteries.
2018-6-6
DJI Wanda
Hello. We apologize that you're having issues with charging your battery. May I know what charger are you using?
2018-6-6
3-D
Flight distance : 635764 ft
Ex Machina Posted at 2018-6-6 11:45
I agree with this assessment.  I would look at the charger.
2018-6-6
SMARL
No, is not the car charger is the original one, the socket charger. Even now, I recharged two deferent batteries, for the first one it takes 1.15h, the other one almost 2.5h.
2018-6-6
SMARL
DJI Wanda Posted at 2018-6-6 11:51
Hi, the original one provided (socket).
2018-6-6
Ex Machina
SMARL Posted at 2018-6-6 12:12
Are the affected battery terminals dirty?
2018-6-6
DJI Wanda
SMARL Posted at 2018-6-6 12:14
I see. What specific Mavic drone do you have? Since when do you have the aircraft? Is it affecting the flight performance and the flight time?
2018-6-6
SMARL
Ex Machina Posted at 2018-6-6 12:22
No, all clean. I store them in to a suitcase.
2018-6-6
SMARL
DJI Wanda Posted at 2018-6-6 12:31
Mavic Pro. I bought last year. The batteries not affecting the flight performance and flight time, everything is ok during the flight.
2018-6-6
DJI Wanda
SMARL Posted at 2018-6-6 12:37
I see. Have you tried to use a different charger?
2018-6-6
SMARL
DJI Wanda Posted at 2018-6-6 13:08
No, I don't have another one.
2018-6-6
DJI Wanda
SMARL Posted at 2018-6-6 13:16
I see. If that's the case, there's a possibility that it's the charger that has a defect since your drone is still working fine even though you're charging the battery longer. You can try to use a different charger to check if it will last 2 - 3 hours again. If yes, please let us know so that we can help you.
2018-6-6
Ex Machina
SMARL Posted at 2018-6-6 12:33
If you have a multimeter handy you can compare the output of the charger to what it is supposed to be delivering in both volts and amperage.
Seems odd, though, that sometimes batteries charge at the expected rate and other times take longer. How stable is your local household power system? Or is one battery consistently charging quickly while another is not?
2018-6-6
davidmartingraf
Flight distance : 106566408 ft
Are you referring to batteries from Mavic Air or Mavic Pro?
2018-6-6
SparksBird
Flight distance : 10731690 ft
Have you tried plugging into a different power source?  Maybe the outlet is bad?  Try another outlet somewhere else in the house trying for a different circuit.  Remember the batteries are the actual chargers the so called charger is just the power source.
2018-6-6
HedgeTrimmer
Ex Machina Posted at 2018-6-6 15:58
To check charger, need to check it under load.  A few ways to do it.  Best would be to monitor charger while it is actually doing its job.  Which would require wiring up a socket and jack to go between charger and battery base.  Could use a light bulb of proper voltage that pulls enough watts to place a load on charger.
2018-6-6
