Balaes
Flight distance : 14241171 ft
Romania
I think i found out why some Mavic Pro users, even if they do not have unpleasant events with the drones, have in time problems with the gimbal, more precisely problems with the ribbon cable. As you can see, the clamp that immobilizes the gimbal directly touches the ribbon cable, which leads to friction and mechanical wear over time. This is present both on the clamp and on the ribbon. So I will give up this clamp, using a protective cap with the immobilisation of the gimbal included. Do not you see this trace of friction?
