Never a choice one over the other, every drone has specific purposes. I will get the Anafi when it is available simply for these reasons, No Embedded NFZ's, 180° vertical span gimbal, supposedly quieter than any of the DJI's, Dolly Zoom, 20 MP camera, 2.4 aperture, portability, USB charging.
Let me elaborate:
The Anafi includes a 21 MP camera, a 180-degree gimbal tilt, 4K HDR video at 30 FPS and 1080p HDR video at 60 FPS. Parrot has also mentioned that the Anafi will be able to zoom in up to 3 times (Smooth Zoom), but that full HD shots will only be able to be made at up to 2 zooms. The camera itself is able to both digitally and mechanically stabilize all captured photos.
The Anafi uses a 3-axis gimbal stabilization system with, as we just mentioned, 180 degrees of tilt. This allows for a much broader range of user freedom when it comes to getting the best shots possible, allowing for footage in the best directions.
The new FreeFlight 6 app will allow users to select 21 MP or 12 MP photos, as well as being able to adjust their video modes. One such video mode is hyper-lapse, which allows for speed footage at a rate of up to 240 times, slow-mo video, and even a high frame rate mode that allows users to film at a rate of up to 60 FPS.
Because the Anafi has a total of 4 antennas, each on the feet of the drone, as well as to the physical controller, maintaining a WiFi connection will be no trouble at all. What’s more, it also has a maximum transmission range of up to 2.4 miles and is able to switch between 2.4GHz, 5GHz, and even 10MHz bandwidths without you having to switch them.
The Anafi, on a single charge, has a maximum battery life of up to 25 minutes, which is charged using a USB-C, capable of fast charging. The smart battery used with the drone is able to detect when it’s running low and give the user a warning before it runs out. It can reach speeds of up to 32 MPH when in Sport Mode, and has a resistance to wind at up to an impressive 33 MPH.
Not an and/or situation simply another choice.
