DMX_MT
Malta
ChrisJG Posted at 2018-6-7 20:23
Good morning, I use a micro 4/3rds camera, as I'm usually carrying my telescope too! Use about 32000 ISO. A tripod is an absolute essential and usually an exposure time of about 30 seconds. But I do have a reasonably fast wide angle lens; a Samyang 12mm f2.8. A larger chip in the dslr would give less noise. 2 years ago, driving home from the Observatory at around (I think) 2-3am the view was stunning, these clouds stretched most of the way across the Northern horizon. I had to stop the car to just take in the sight, it was mesmerising. But of course my camera was at home in its case!
Good hunting!
Chris
Hi Chris,
I think what you must do, is to use some type of HDR Technique.
If you are using those type of lenses and long exposures for your Shots, it will be impossible in my opinion to achieve with a Drone.
If it was me I would experiment by taking the Sky Shots with your Equipment as usual, then fly the Spark at the Altitude you need (You will be replaceing the Sky), take the shots, put them both in Photoshop or your Post Editing Program you use and superimpose them.
Its take a lot of Hard Work and Trial and Error, but it would be worthed.
Also thanks for the Info re the Equipment, will surely have a look.
