Robertodst
Flight distance : 57290 ft
DJI Diana Posted at 2018-6-8 01:21
Hi, I'm sorry to hear about the issue that you are experiencing. May I confirm that do you use the original SD card that comes with the drone or not? Please check all the original videos to see if all of the videos have the issue or only one? At the same time, please provide a sample/original video to us, we'd like to check it. Thanks!
Unfortunately I have a similar problem, not on the video transmitted to the mobile phone, but on the video recorded on the SD card.
The video lacks some very short intervals, it is chopped.
I googled and found that many people complain about the same problem, in particular this link clearly shows the problem (it is not the only one):
https://www.youtube.com/watch?v=YuD3qG4hjms
As you can see the video is not smooth and fluid.
I've tried changing all the recording parameters, practically all the combination of resolutions and frame-rates, but the problem always arises, when less when more, in all the cases.
The mavic firmware is updated to latest one.
If someone thinks that the SD card I am using is not suitable then we must also establish that a SunDisk Extreme 32GB V30 U3 is not suitable for use in the mavic air 2.
If someone thinks that my PC is the cause of the problem in the playback phase we should understand which system should be better performing than this
* -memory size: 63GiB
* -cpu product: Intel (R) Core (TM) i9-9880H CPU @ 2.30GHz
size: 4446MHz, capacity: 4800MHz
NVIDIA Quadro RTX 3000 Max-Q
I am very afraid to notice that this defect is clearly present in all public videos made with the mavic air 2. This could mean that the problem cannot be easily solved with a setting or with the replacement of a different SD card, or other than the user can do.Really I hope this is not the case.
Thanks for your suggestions
