DJI Phantom 4 Pro V2.0 new but with 38 flights
1207 15 2018-6-8
RemusK
Flight distance : 1145869 ft
Sweden
Hello!
I've bought a new DJI Phantom 4 Pro V2.0 and after connecting to DJI Asistant I saw that there was already 38 flight logs.
What logs are they? The first log was on first January 2018. I've bought mine for a couple of days ago, brand new.
/Remus
2018-6-8
DJI Wanda
Hello. Thank you for reaching this concern to us. Can you provide me your serial number so that I can check it here in my end?
2018-6-8
Nigel_
Flight distance : 388642 ft
Excellent - it's been well tested!
Was it activated, or did you have to activate it?
2018-6-8
RemusK
Sweden
DJI Wanda Posted at 2018-6-8 07:27
Hi Wanda! I have sent it as a privat message.
2018-6-8
RemusK
Sweden
Nigel_ Posted at 2018-6-8 07:43
Thanks. I had to activate it.
2018-6-8
Matthew Dobrski
Flight distance : 1831050 ft
Not all logs are related to actual flights. Every time the system is powered up for whatever reason (i.e. in factory set-up, feature testing, FW update etc.), it leaves a log record behind. Open box and no activation request, however, may rise some suspicions. Simply check flight records if any were actually done. There you'll also see who's the owner of this drone.
2018-6-8
Rodger8
Flight distance : 20145135 ft
I was wondering where my Demo ended up? Seriously, did you use a previous Phantom with your Tablet/Phone? In looking at your flight distance and I just noticed that you have or had a Phantom 4. Is it possible that you are seeing previous flights? At he bottom  left of your flight log window you can scroll through all of your activated drones. That should help you sort things out.
2018-6-8
RemusK
Sweden
Rodger8 Posted at 2018-6-8 11:53
Yes, I still have the other Phantom. But I see the flight files (dat) in the aircraft. I was not meaning the mobile app
2018-6-8
Nigel_
RemusK Posted at 2018-6-8 07:55
My guess is that they take a few off the production line and give them a thorough testing while most go through with almost no testing, and you got one of the ones that has been properly tested.  But lets see what Wanda finds out...
2018-6-8
DJI Diana
Flight distance : 2408 ft
RemusK Posted at 2018-6-8 07:54
Thank you for providing the serial number, as per check, it was activated at 2018-06-07 01:44:47, it seems there is no problem with your drone. If you still curious about the logs, could you please export all the logs so that we can forward it to our engineers for a check?
2018-6-8
Rodger8
RemusK Posted at 2018-6-8 12:47
Thought you were referring to flight log. It will be interesting to hear the explanation for that.
2018-6-9
DJI Diana
Update:
Hi Remus, sorry for the inconvenience, I have helped you confirmed it with our engineers, to know that it is normal because the drone will be tested before leaving the factory, so please don't worry about it. You are recommended to check the performance of your drone, if there is any further issue, please feel free to let us know. Happy flying.
2018-6-11
RemusK
Sweden
DJI Diana Posted at 2018-6-11 02:25
Update:
Thanks for update
2018-6-11
DJI Wanda
Hello. Thank you for patiently waiting. It is really normal for a drone to have flight logs even it's a brand new one. Drones are being tested by our engineers before leaving the factory. I just want to confirm, is the drone works fine?
2018-6-11
RemusK
Sweden
DJI Wanda Posted at 2018-6-11 02:56
The drone works perfect
2018-6-11
DJI Wanda
RemusK Posted at 2018-6-11 03:02
Alright. That's good to know. Let us know if anything happens unusual and we're here to help.
2018-6-11
