Video correction attempt
373 3 2018-6-8
fans55bcfca4
Hello, everybody,
since last weekend I own a DJI Spark and I noticed that when I create a video, it is only visible while playing it (mobile phone and PCs) like in green tones, probably what was tried to correct?
For a better explanation I made a short video on youtube! Search keys : a0275970 , Videoaufnahme , Korrekturversuch
Video settings are set to manual and tested with different ISOs and shutter speeds.
Maybe there's something I need to keep in mind.
First of all, many thanks for the answers.
Greeting Ralf
2018-6-8
davidmartingraf
Flight distance : 106566408 ft
The Spark comes out of the box with automatic camera settings, as there's not much you can do except adjust its white balance, ISO, and shutter speeds. I don't know how effective that will be because the camera changes image so much as it flies. Usually if a sunny day then those manual adjustments will be less effective, and vice versa.
2018-6-8
fans55bcfca4
I found the reason. Instead of watching the video in the library as the "original", I watched it from the "mobile device cache".
Library (bottom right) - Play video - select "Original" at the top.
Thanks for your answer.
2018-6-8
pmshop
Flight distance : 8073271 ft
fans55bcfca4 Posted at 2018-6-8 10:35
Glad you found the issue.
If you need us to see videos of issues In the future, just post the YouTube link here.
2018-6-8
