Flying backwards..
824 10 2018-6-9
Torkild, Norway
Flight distance : 26273 ft
NO SOUND.
Trying to learn to fly backwards.
A bit scary actually...
2018-6-9
solentlife
Flight distance : 1087530 ft
Latvia
Some of those are a bit close to tree / cables and postboxes !!
You are into what is termed orientation in the general model world. The action of reversed controls while others stay same. It takes a lot of practice in model flying and is usually learnt by doing fig 8's flights out in front .. this makes the 'mind' have to swap control action and get fingers to work right direction, while still developing general ability.
The 'drone' of course has an advantage of being able to stop and hover .. but you still have that change of control orientation to master.
Cheers
Nigel
2018-6-9
jacksonnai
Malaysia
Hey phantom what u are using ?
2018-6-9
jacksonnai
Malaysia
Dirty Bird Posted at 2018-6-9 05:22
But it presents a whole new perspective!
https://youtu.be/f6_HxLSP8LM
Nice shot !
2018-6-9
Montfrooij
Flight distance : 2560453 ft
That can make for a nice effect!
2018-6-9
Nigel_
Flight distance : 388642 ft
It's a lot safer if you fly forwards, then reverse the video in the editor ;)
2018-6-9
Torkild, Norway
Nigel_ Posted at 2018-6-9 13:36
For sure, but then, whats the trill ?
2018-6-9
ALABAMA
Flight distance : 10442687 ft
Thrill might be not crashing your expensive drone into a tree ;)
2018-6-9
sky wombat
Flight distance : 1469341 ft
Reckon with the powerlines and trees forwards would be enough of a problem.
At least some of the neighbours won't complain if it suddenly goes down.
2018-6-9
Rivi
Flight distance : 74521 ft
United Arab Emirates
One advantage of flying backwards is no chance of getting your props on the photo.  Ofcourse this will be a problem solved only if you are flying fast.
2018-6-9
KedDK
Flight distance : 1133038 ft
Denmark
It just look incredible strange when the birds are flying backwards too, not to forget vehicles etc on ground.
Often when seeing this, the subconsciousness mind just know from unnoticeable details that something is wrong, same goes for photos rotated/flipped or mirrored, even the motive shouldn't matter you just sense that something is odd.
2018-6-10
