Cetacean
Flight distance : 2528264 ft
Mark Weiss Posted at 2018-6-10 17:05
It seems like the RC powers up when the charging cable is plugged in. So maybe the CS is designed to power on when it detects the RC powering up?
That CS Ultra is so flakey that I am reluctantly reaching the conclusion that I'd better return it before it causes a drone crash. The software hangs when the temperature is above 70 degrees, it does strange things that are unexpected. My camera setttings change all by themselves.. I was accidentally recording 4K 30P today and didn't realize til the end of the flight that it had changed from 4K 24P where I always film at. The still mode changes to JPEG when I last used it in RAW, the Intelligent Flight modes cause the video feed to stop working or to freeze into blocks of grey embossed like images. And today, the drone veered off to the left unexpectedly toward a stand of pine trees while in IFM doing a close range follow of a large, high contrast target. That's pretty much the last straw. I never had ANY of these things happen when I used my Samsung Note 5 to control the drone, even on an 88 degree afternoon. I just couldn't see the screen well enough to fly safely.
Aloha Mark,
Over here we are dealing with three CrystalSky Ultras and I was able to reset the one that was acting like yours. One we had to return for a replacement for a mainboard issue. The original one, the replacement and the reset one are working fine now. So, there is a light at the end of the tunnel.
You have to reset your CrystalSky Ultra or it will continue to misbehave. Sure you can return it, DJI will reset it like I told you to do and then return it to you. Save yourself some time.
If you tried to take a photo while recording a video, DJI GO 4 only allows JPEG photos. There is not enough processing power in any current tablets to record a High-Volume photo like a RAW .png photo while recording video. If you want to record RAW while recording video, you have to stop the video and then take the shot and then restart the video. JPEG, not problem, same time, but RAW, forget about it.
When we have a piece of equipment that acts differently than expected, we pay much more attention to it and often unfairly blame problems on that piece of equipment for unrelated issues. Sure, you can return your CrystalSky Ultra and buy a different tablet, but at some point, you may realize that you should have had some more patience and looked at more detail regarding the problems you are describing.
My friend with the three CryatalSky Ultras (two for the company he flies for and one of his own) quickly got into a similar mind-set that you are writing about. He is now happily on board and realizing what a nice product the CrystalSky Ultra is.
Your IFM aberrance looks like a Phantom issue to me, not a CrystalSky issue. It takes much more than a few odd-ball steps and issues before you make a drastic decision like quitting a product completely. You have to pay attention and analyze everything that happens to generate your problems. We are not experts with the new DJI equipment, but we are the front line trying to make sure it works as advertised. But, before we make a claim, we have to be sure that our claim is accurate.
Hope this helps!
Aloha and Drone On! |
