hallmark007
Flight distance : 9827923 ft
Imu exceptional heading is often caused by problems with compass, I see from your log that you seem to have taken off from what looks like an industrial yard of some sort. Is it possible you picked up some interference on the ground there before take off, it won’t necessarily show on your app but problems can start in thr air and not always straight away, I will explain below.
Magnetic interference on the ground taking off on ground which contains rebar concrete underground cables, a few things you need to know, what happens to aircraft resulting from taking off in these areas.
I will try to explain.
First if you start up your Aircraft in a safe area, without taking off lift up your Aircraft by hand and rotate 90 degrees, both compass and IMU will follow to this new heading, so no problem this is how it should be.
Taking off from mag interference ground will cause your compass to move it’s heading this does not always show up in your app, so it will still allow you to take off.
Once you take off and get clear of mag interference your compass will then correct itself but the movement made by compass causes confusion in your IMU because it is designed to move with compass.
This you will see reported on your app as IMU exceptional heading compass error, switch to Atti mode, your aircraft cannot cope with conflicting data so it will usually drop gps in favour of compass.
And although all of above didn’t pan out, it’s most likely that your compass was off the heading at launch corrected itself but at the same time confusing IMU causing exceptional heading. |
