hallmark007
Flight distance : 9827923 ft
Should I do a preflight check. Simple answer YES.
WHY:
There are many good reasons for doing a preflight checklist and none I can think of for not doing a preflight.
1/ preflight check is the best way of insuring you have checked all possible working elements of your drone, and the only way you have of knowing if your aircraft is safe to fly.
2/ the simple fact you have done a precheck will give you much more confidence about flying.
3/ if anything is not ok you will be able to track this before you ever leave the ground, and will have time to sort problem.
HOW:
Preflight checklists can vary and their use can depend how much time operators feel they need to spend on preflight check.
For commercial users preflight is an absolute, and should be done with physical checking and checking off all items on their checklist.
You should print off your preferred checklist and keep it in your flight bag, but should always go through before each days flying, it will also give you a record that before you flew that all was checked and working as it should, you can also use a new printed preflight checklist like commercial pilots each time , this will give you a personal record it will also be a record to show others that you have physically checked and marked off everything as in good working condition before you flew, particularly if on your flight mission you happen to have problems.
I’ll leave below copy of preflight checklist, it’s commercial so don’t think you have to complete all that’s in it before you fly.
But feel free to use any parts you find relevant to your flying experience.
Once you start using preflight checks from your own list you will find that it will become second nature to look for it in your bag before you take off.
Good Luck Fly Safe.
1. Pre-Departure Check | | 3. Pre-Flight Check | Aircraft | Checked | | Airframe |
| Tablet | Charged | | Airframe | Undamaged | Firmware | Updated | | Motors | Rotating & Free of FOD | Maps | Cached | | Propeller | Tight and Secure | Camera | Lens Cleaned / Checked | | Battery | Voltage Checked & Secure | SD card | Format | | |
| ND Filters | Checked | | Transmitter |
| Gimbal | Checked | | Antenna | Set | Spare Props | Checked | | Battery | 50% or greater. | Lipo Batteries | Checked / Charged | | Transmitter | Power On | Charger | Checked | | Tablet/Phone | Connect & On | Take-Off Pad | As required | | App | Launch | Ops Manual | Checked | | |
| Logbooks | Checked | | Gimbal/Camera | Attached/Checked | Tool Kit | As required | | SD Card | Inserted | Anemometer | As required | | Aircraft | Power On | |
| High Vis | Checked | | Settings |
| Protective Glasses | As Required | | Flight Mode | Set | Fire Gloves | As Required | | Flight Limits (Vert/Hor) | Set | Fire Ext. | Checked | | Return to Home Height | Set | First Aid Kit | Checked | | Compass | Calibrate (if Required) | Cones / Cordon Tape | As Required | | IMU | Level (If Required) | Signage | As Required | | Camera Mode | Set | Table / Gazebo | As Required | | Battery | Capacity Checked | | | | Telemetry & Satellites | Checked | 2. Set Up Check | | | |
| Site Safety Assessment | Confirmed | | ATC | Advise (If Required) | Emergency Landing Sites | Identified | | | | Weather | Checked/Recorded | | | | Brief | - Actions: 3rd Party | | | | | - Actions: Aircraft | | | | | - Emergency Land Sites | | | | | - Pilot Incapacitation | | | | | - Risk & Mitigation | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 4. Take-Off Check | | 5. Shutdown Check | Communications | Check | | Aircraft Battery | Off | 3m Safety Zone | Set | | "Safe" | Announce | "Rotors On" | Announce | | |
| | Airframe | Undamaged | Take Off Area | Clear | | Propellers | Undamaged | "Taking Off" | Announce | | Motors | Rotating Free & Temp | |
| | Camera/Gimbal | Checked | Flight Controls | Check | | Logbook | Recorded | Telemetry | Check | | ATC | Advise | Battery | Check | | |
| | 6. Between Flight Checks | Landing Check |
| | New Battery | Insert | Recording | Stop | | Battery | On | Landing Area | Clear | | Battery | Capacity & Voltage Check | 3m Safety Zone | Set | | Telemetry & Satellites | Checked | |
| | Take Off Check | Commence | "Landing" | Announce | | | | "Rotors Off" | Announce | | | | | | | | | | | | | | | | | | | | | | | | | SUA Limits | | | Max Wind Speed | 22mph | | | Max Temperature | 40° C | | | Minimum Temperature | -10° C | | | Max Descent Speed | -4mps | | | Max Speed | 18mps | | | | | | | | | | | | | | | | | | | | | |
