Tilt stiffness can't be more than ~20 in RONIN-M
1530 1 2018-6-10
sijia
I'm having issues with the tilt axis.
I balanced the camera correctly and as described by DJI. I auto-calibrated and the tilt axis stiffness sets it at 12. I can push it to at most 22 before it starts to vibrate. The problem with this is that low stiffness makes the tilt moves looks bouncy and shaky. Attempting for a few seconds to set the stiffness to 40, the bounce goes away, but obviously after a few seconds it vibrates like crazy.
I tested this with two different cameras and it's the same thing. Can't pass 30 as recommeded by DJI because it start to vibrate.
Is the ronin-m tilt motor broken? does anyone know what's going on? Thanks.
2018-6-10
Please try to restore the device to the default settings in More, then make sure the camera has been balanced well, adjust the stiffness of the three axis to 25-30 to see if the issue persists. If yes, any chance to post a short video here for further support? Thank you in advance.
2018-6-12
