Geebax
BramLaurens Posted at 2018-6-11 12:25
I tried some more flying and yawed in and out of the sun a few times to see when the problem starts. I found out that sometimes the problem just doesn't show up even when filming directly into the sunset but a few seconds later when I turn into the sunset again the image looks almost fine at first but then the glitching sort of just slams into the picture as if the software is trying to adapt to the bright light (@0:22). Could still be a software problem maybe..
https://www.youtube.com/watch?v=DiDTxiC-_X8&feature=youtu.be
No, it is not software, it is a camera hardware fault. It can be caused by the ribbon cable, but it does not have to be visible damage, it can also be caused by the ribbon cabl;e connector not being properly seated at either end. Personally, I would send it in for repair.
