Where is the Flight simulator
12Next >
4803 47 2018-6-11
Hawk2
Flight distance : 3661 ft
Japan
I have a Standard 3 with DJI Go app version 3.1.34 and I do not appear to have the flight simulator. I am using a Lg g2 phone and when I go to the top right corner instead of a graduation hat I see 3 lines horizontal lines (menu) and when I select it academy pops up but when I click on it nothing happens.
any ideas? should there always be a simulator?
2018-6-11
TheLazyC
Flight distance : 1357356 ft
2018-6-11
Hawk2
Japan
I have alrady seend that video and my DJI version 3.1.34 doesn't have that menu.
2018-6-11
Hawk2
Japan
this is what I see.
2018-6-11
ArgenBrewer
Flight distance : 18638 ft
I have a Phantom 3 Standard, with DJI Go v3.1.38 but my simulator does not have the graphic details of the one shown in the video, there is no grass or hills, just a flat green surface. Does anyone know the cause?
2018-6-11
Hawk2
Japan
ArgenBrewer Posted at 2018-6-11 20:04
Where is the simulator? Does it matter what type of phone I have?
2018-6-12
Hawk2
Japan
I have DJI firmware 3.1.34  I dont know what argenbrewer is talking about
2018-6-12
Betamace
Flight distance : 2133 ft
Hawk2 Posted at 2018-6-12 00:31
The iOS version of the sim has the hilly terrain which is sort of better than the flat terrain in the android version however, choice of different viewing perspectives are not present in the iOS version. Also, the android versions of the sim is nearly unplayable when flying unless you have a top of the line display device. When I first flew the android sim my impression was that I was rollerskating on ice so I upgraded to iOS.
2018-6-12
Hawk2
Japan
I am not able to find or run the simulator on my DJI GO application. The screen only shows "academy" Can anyone tell me why?
2018-6-12
Peterx
Flight distance : 1499708 ft
Tab on academy and the pop up menu shows up the simulator. Then tab the simulator.
2018-6-12
ArgenBrewer
Hawk2 Posted at 2018-6-12 00:52
[view_image]
These are the differences of which I speak ..
2018-6-13
Hawk2
Switzerland
Peterx Posted at 2018-6-12 22:23
When you say tab if you look at my screen shot you can see Academy. I can't click on Academy. There is nothing else on the screen other than Academy
2018-6-13
Hawk2
2018-6-14
Peterx
Tab on <Academy> ,then you get the menu for flight simulator,video academy,flight tutorial and users manual. Tab on flight simulator <Enter> and power on your P3S system.
On my MpMan and iOS is it available. May be your phone does it not handle.
2018-6-14
DJI Thor
Flight distance : 13602 ft
Please refer to Peterx's suggestion, click "Academy" then you will be able to enter the simulator. Please keep the drone and RC connected when using the simulator.
If there is no reaction after clicking it, since the latest app is v3.1.38, you can try to update the app and test again.
2018-6-15
Hawk2
Japan
DJI Thor Posted at 2018-6-15 02:46
I have tried clicking on academy with the drone and controller on and active. IDJI go app will not respond to a click. When I upgraded it did the same.
If I have the drone and controller off should I be able to pull up the menu?
2018-6-15
Peterx
What android version is on your phone? RAM and CPU can handle the app easy. Do you have any other apps running in the back round?
If yes then force to stop all for flight NOT needed apps,and then start the Go app.
2018-6-15
DJI Thor
Hawk2 Posted at 2018-6-15 13:03
Sorry to know that it doesn't work after upgrading the app. It can be pulled out the menu after clicking the menu. In your case, you might try another mobile device and see if it is a compatibility issue.
2018-6-16
Hawk2
Japan
DJI Thor Posted at 2018-6-16 02:27
Does anyone have a visual demo of this version. My screen does not match what is shown on the youtube sites. Mine has 3 lines followed by "academy" when clicked but others have graduation hat.
Since it works in flight is there any diagnostic checks or parameters that might effect the flight simulator? i don't have any other apps running when I try to engage the flight simulator. Also I would like to know if I can expect a menu to appear even if the Drone is not on?
2018-6-17
Peterx
If the drone is off then the simulator give a message to power on your AC.
2018-6-19
Hawk2
Peterx Posted at 2018-6-19 10:09
Can you get a siulator menu? All i see is what is on the screen shot.
do you see the same menu?
2018-6-19
Peterx
Yes i got the menu for simulator menu if the drone is off.
2018-6-20
Hawk2
Peterx Posted at 2018-6-20 06:59
That is strange. I do not get the menu and I tried it on a Lgg3 and I get almost the same thing except it adds "flight restrictions" below "academy"
Does your menu look like mine?
2018-6-20
RedHotPoker
Flight distance : 165105 ft
The best way to practice with a flight SIM is buy one.
See www.realflight.com Drone version.
RedHotPoker
2018-6-21
Peterx
I´ll make a screenshot of my menu of the academy and the following menu.
2018-6-21
RedHotPoker
Peterx Posted at 2018-6-21 09:08
Ok. Thanks...
RedHotPoker
2018-6-21
Peterx
Here is the shot of my simulator on iOS
2018-6-22
Hawk2
Japan
I am looking for someone that has the same menu as mine and the flight simulator works
2018-6-22
Peterx
I´ll make a shot of the android too.
2018-6-23
Peterx
Here is the android shot of the Go app same version as on IOS :
2018-6-23
KedDK
Flight distance : 1133038 ft
Denmark
Peterx Posted at 2018-6-22 10:19
[view_image]
How does your screen look one step before you enter the academy section, does it look anything like the one OP has posted several times down the thread?
And to be clear, you just tap/poke/press the academy link to enter the above screen right? - no swipes, dragging or other fancy messing around on the display.
2018-6-23
Peterx
Exactly as you say,its a step further than enter academy,but i dit it with my iPkone6 for iOS  and on MPQC for Android. I did´nt swipe screen to tab above right to reach these menu .
2018-6-23
JSKCKNIT
Flight distance : 1208566 ft
Holy....that's like Atari compared to XBox!
2018-6-24
Peterx
JSKCKNIT Posted at 2018-6-24 02:18
... or compared between the Vanilla Freespace2 and Freespaceopen
But the menus are the same. Tab the 3 horizontal lines for <academy> tab on <Academy> an get these menus i posted.
2018-6-24
Hawk2
Peterx Posted at 2018-6-24 08:32
But the menus are the same. Tab the 3 horizontal lines for  tab on  an get these menus i posted.
I am looking for someone to post an Android version that has the "academy" option and works!
2018-6-24
KedDK
Denmark
Hawk2 Posted at 2018-6-24 21:27
That was what Peterx posted up in #30?
To start the sim from there would be a question of a tap on the "Enter" at the blue banner.
2018-6-25
Hawk2
KedDK Posted at 2018-6-25 05:15
Compared to my post the screen capture shows only a small rectangle in the top right but Peterx shows "academy" as a banner across the top part of the screen. So that is what i should see? He is running IOS I am running Android.
If so is there an official supported device or operating system? I am running Lolipop on lgg2. I would be surprised as I am not loosing any functionality that I am aware when flying only the simulator.
2018-6-25
KedDK
Denmark
Hawk2 Posted at 2018-6-25 22:15
That is because Peterx's screenshots is taken after he tapped/poked/pressed the Academy button/link shown in your pictures.
I don't know if your device lack of compatibility but usually you'll find a list of tested and recommended devices in the download section of your model, see end of the specs here.
2018-6-25
Peterx
The first screen shot was from iOS 11.4 and the second shot from a not listed device MPQC96i with Lollypop. I ´m do use both iOS and android. Android i´m using in a rural area and iOS in the near of  area with known interferences,iOS WIFI is stronger a little bit.
2018-6-26
Hawk2
Japan
Peterx Posted at 2018-6-26 05:16
I do not see a Android screen shot.
2018-6-26
12Next >
