DJI Thor
Flight distance : 13602 ft
The recommended list is on the corresponding production webs, as you have Inspire 2, you can refer to the screenshot below.
If you are going to fly directly under the sunlight, Crystalsky is a good one to consider. Crystalsky is created for outdoor aerial imaging, the CrystalSky monitor features an ultra-bright screen that is clearly visible in sunlight. It is designed from the ground up to work seamlessly with the DJI GO app, giving camera operators total control.
Hope the info helps you with some hints.
