FanOfFlight
Flight distance : 1983760 ft
figure1a Posted at 2018-6-14 19:21
Seems like this has always been a DJI problem. Many camera settings and other aircraft settings get changed during a firmware update, fresh power up, battery swap, etc. DJI should make a setting where you can save your settings offline to your iPad or dropbox and then reimport them after you do a firmware update, etc.
I think the app should let you backup your settings, and also sync those with icloud so if you fly with different devices you can still ensure you have ability to keep settings exactly like you want them.
This is an area that DJI completely ignores. Firmware should not wipe settings. At least if the update process would read, save then restore while doing an update that would enough.
Either way, they should focus on this more then they have done.
