A dark image of fpv. During the flight on sunny days.
588 3 2018-6-12
Grzegorz
Flight distance : 44049 ft
Poland
A dark image of fpv. Could you add options for brightening the same fpv Image in dji go?
2018-6-12
Mark The Droner
Flight distance : 2917 ft
Be sure your mobile device is set to max brightness when you fly - not the battery-saving brightness.
2018-6-12
Grzegorz
Poland
It's on every device when you focus on the ground it's all visible. Unfortunately, the image on the SD card is too bright later.
2018-6-12
Peterx
Flight distance : 1499708 ft
What cam setting are present in the App and copter,and is that issue on all your mobiles you tested ?
2018-6-12
