Sanders Aerial Posted at 2018-6-12 09:00
the problem is the the crystal sky. if we use the iPad the problem doesn't exist. we found a workaround. If you turn EI mode off and then on again, you get the waveform PIP, then you can minimize the waveform and see only the camera gimbal image. But if you close the waveform, it is replaced by the FPV camera PIP, and if you minimize that, the camera gimbal image becomes a blank screen than fluctuates subtly in colour.
We have been aware of this issue and will get it addressed in the next version of built-in DJI Go 4 APP.
Currently, please do not switch to the FPV screen. Or please downgrade the CrystalSky firmware v02.06.03.00 via SD card, for more steps, please check here: http://dl.djicdn.com/downloads/C ... Sky_Firmware_EN.pdf |
