BumblerBee
Flight distance : 639764 ft
Norway
When I took my Mavic out for the first post-winter flight at the end of May, I suddenly noticed a peculiar problem.
Whenever I start recording video, the live feed in the app began stuttering - the feed would either freeze for about a second or show pixellation. As long as I do not record, the feed is perfect. The video recorded to the SD card is always perfect. The aricraft responds to the commands perfectly even when the video feed freezes.
I have iPhone 6S Plus running iOS 11.2.6 (updated from 9.3.5 dring winter)
Mavic, controller, batteries and the app were updated to the laterst firmware.
Since then I tried the following to eliminate/narrow down the problem, and think it is a bug in GJI Go 4 app.
- My first suspicion was radio interference, but the problem occurs even if Mavic is hanging 1/2 meter away from me. Still, I tried several different locations and distances.
- My second suspicion was that the phone with iOS11 stopped being powerful enough to record to cache, so I disabled caching of the recorded video. The problem persisted.
- I then tried different resolutions, thinking that that may be the problem. I usually record at 2.7K, but went down 1080p 25 fps (also tried 4K). Still stutetring.
- I turned off live histogram view. Still stutetring during video recording.
- I went then to the Image transmission settings in the app and set it to "smooth" - that did not help either.
- The final test was to launch Litchi (I only used it occasionally for WP, preferring Go for the familiarity I have with it, and the cloud flight sync and stats). Litchi DID NOT dispay this problem - I recieved fluent, perfect video feed, regardless if I was recording a video or not!
This leads me to conclude that the problem is a bug in DJI Go 4 app. It effectively makes the app useless as controlling of the aircarft for a smooth video footage composition becomes impossible. I will have to use Litchi and forego the flight stats until the problem is solved, as video recodring being the primary function I use my Mavic for.
