4350Mah Battery charger
1631 5 2018-6-12
Ionut D
Romania
Hello,
I just got a 4350mah battery, and a 57w charger. Unfortunatelly I noticed that it is the phantom 3 charger. Will that work to charge the battery? I had it plugged in for more than one hour and not noticing any change.
2018-6-12
They are not compatible, please charge the 4350mah battery with its dedicated charger.
2018-6-12
Ionut D
Romania
DJI Mindy Posted at 2018-6-12 22:30
What is the difference between the chargers? I see they have the same voltage/current
2018-6-12
Ionut D
Romania
Ionut D Posted at 2018-6-12 23:11
also, is this a swollen battery?
https://www.dropbox.com/s/yu9jwngplnwgklf/IMG_3892.MOV?dl=0
2018-6-12
Ionut D Posted at 2018-6-12 23:12
Yes, the battery is swollen, if it is still in warranty period, please contact our support team to start a ticket for further assistance.Please use the dedicated charger, if there is any issue caused by other charger, the warranty service may not be provided. Thanks for your understanding.
2018-6-13
Ionut D
Romania
DJI Mindy Posted at 2018-6-13 02:10
HI
So I replace the battery at the store where I bought it from, I also purchased the right charger, now the only issue is this:
- when I plug the charger in - it seems to "load" the leds couple of time, and after that it keeps the "low" led blinking. I kept it plugged for like an hour - and nothing seems to change.
Wasn't it supposed to keep "loading" while it is charging?
https://www.dropbox.com/s/3wv5gtl20ln6ky7/IMG_3896.MOV?dl=0
2018-6-14
