3-D
Flight distance : 635764 ft
HedgeTrimmer Posted at 2018-6-12 12:11
I think you can only edit the recorded Live Stream view using GO-4 App.
If you want to edit High Quality video that is stored on microSD card in drone, you have to remove microSD card from drone, and put it in a card adapter, to transfer it to your computer. Where you will need video editing software. If drone's video was done at say 4K resolution, you are going to need a computer system capable of viewing 4k and horsepower (CPU, Memory) to do any serious editing of 4K video.
or power up the aircraft and plug in the USB-C cable. the internal storage and the SD card will show as sources. You can download from there, but again this is to your computer.
I had the same problem in using the video editor in the app on the phone. it would show that is was starting to download and then just never finish. I didn't work at all in getting it to work. it didn't download and i just said "F it, i'll download from the aircraft."
You should also be able to download the stream from your phone to your computer. It is in a DJI folder on your phone file system.
