KedDK
Flight distance : 1133038 ft
Denmark
Evgeny SPb Posted at 2018-6-13 06:16
I tried. I went into the flight app. "Tap the map down left to enlarge it, scroll to the area you want to fly in.
Scroll around to ensure you get the needed area covered also in different zoom levels to get the details" - it is OK, but I've never had a problem with that before. I have maps of my region, I uploaded them long ago. But when I was traveling, I downloaded the maps of the region before the trip. And for that, I used the map selection in the maps section of the start screen, not in the flight app. Soon I have to go to Crete. How do I get the Crete maps? After all, the maps section is not available. Will they downloaded in the new region when I turn on the copter already in the new place, maybe?Thank you for your patience and help.
New region: Yes it should work the same way but require that you have the remote online when caching the maps.
The alternative could be, while at home, to zoom out as much as needed and then zoom in to Crete and scroll around there. I can't test that possibility as my equipment is on visit at DJI in the Netherlands, but you should be able to see if that would work out for you.
There should be an update on the way that re-introduce the download somehow as we are used to know it, but when it comes is hard to say.
It seem that the developers collect a pile up of fixes and changes before releasing instead of releasing fixed issues as they are solved.
Best luck with it and have a nice trip when time comes. |
