Quickly Find Duplicate Files on Mac
2709 5 2018-6-13
djiuser_ha23ps0FDHQo
If one day is good, you will find that your hard disk space is almost finished. You should start cleaning it up. Unfortunately, clearing cache files may not be enough to release large amounts of disk memory. In this case, it is time to find and process duplicate files, which may occupy important space on Mac. Here is the Method.
Method 1 - manually Find duplicate files on Mac
When you decide not to use third-party software, the process of finding and removing duplicate photos, documents, music or video files is not so simple and quick. Anyway, let's look at how to manually find and delete duplicate files on Mac.
One way is to sort files by size using smart folders in Finder.
Open the Finder window.
Go to Apple Menu > File > New Smart Folder.
Click the plus button on the upper right corner and select the search parameters: type, date, name, file type and so on.
Method 2 - Automatically find and clean duplicate file
Step 1: Download and LaunchiMyMac-Cleaner  in here. https://www.imymac.com/
Step 2: Choose Duplicate Finder Option and click scan button
Step 3: select duplicate file to clean
Step 4: Wait for cleaning complete
Hope it can help you. Welcome feedback
2018-6-13
Louis Juff
Poland
I have been using DuplicateFilesDeleter. It is quite good. I will give a chance to yours as well. You can also try DuplicateFilesDeleter if you ever come across problems with this one you have suggested.
2018-6-18
kelgbla
China
In my own opinion, TunesBro CleanGeeker is better for removing duplicates on Mac. scan is faster and can find more duplicates on entire drive. You can check the tutorials from here.
2018-10-16
Garry_Braun
Bulgaria
If you want to find , delete or both files, you can try some program like DuplicateFilesDeleter, which is very good in my opinion for this purpose.
2019-3-23
djiuser_f9B6XQasjsy8
iMyMac's Mac Cleaner can help you find the duplicateVideos, Music, Images, Documents...and to clean up.And iMyMac's Mac Cleaner software is free to use!
2019-8-8
DAFlys
Flight distance : 868563 ft
thanks for the tip.
2019-9-9
