I have problem with horizontal gimbal stabilization in P3A. Everything works good and for an unknown reason image start to shake horizontal when I rotate drone.
Please look at videos.
It surprised me that when drone hang in the air and I rotate it right side the image view is smooth and no shake is visible. But, when I rotate left and stop rotating, gimbal shake with some oscillations.
When flying the problem is much more visible and is present all the time.
Sorry for this trouble. The steps that you have done are actually correct. Have you tried updating or refreshing the firmware of your aircraft? If not, kindly perform the firmware update and re-calibrate the gimbal. Please let us know the result. You may check the video below:
As I said I made refreshing aircraft firmware and after that IMU and GIMBAL calibration. Nothing change.
Sorry, I overlooked that part. If that will be the case, then you need to send in the unit to our facility to diagnose the problem and repair it. You may click on the link to start the process: http://www.dji.com/support
