Problem with Latest DjiGo4 Version 4.2.20 - Video Lag
3612 13 2018-6-13
AForceOne
Flight distance : 7724367 ft
4.2.16 was super stable for me with no issues. However, as soon as I updated to 4.2.20 it is having video lag on both Mavic and Spark (with OTG). Samsung Galexy S7 here. Anyone else having issues ?
2018-6-13
QuadKid
Flight distance : 482349 ft
Try using the the USB-A port on the Mavic controller, not sure about the Spark as I do not own one.
2018-6-13
DJI Gamora
HI thank you for reaching DJI forum, we apologize if you are having issues with the latest version of the DJI Go 4 app, having said that you already updated the version, try also to update the android version of your mobile device . Hope this resolves the issue.
2018-6-13
AForceOne
Firmware stayed the same. Only the Android DJIgo4 got updated from 4.2.16 to 4.2.20.  Phone has the latest (available) software applied. Android 7, Security Patch is April 1, latest available for download.  Kernel 3.18.31-12142063.
Will try to role back to 4.2.16 if i can.
2018-6-13
AForceOne
I found online an APK for 4.2.16 (not sure if we are allowed to post link) and once I installed it (removed .20 first) everything is back to normal with no issues. Have filed out a support request for this "bug" but on 4.2.16 I am good and stable.
2018-6-13
nywrecker
Flight distance : 832421 ft
AForceOne Posted at 2018-6-13 16:16
Pls post link.
2018-6-13
Optimus Prime-Mavic Air
Flight distance : 568704 ft
Vietnam
You can find it here for Android: https://apkpure.com/dji-go-4-for-drones-since-p4/dji.go.v4
2018-6-13
AForceOne
I used https://www.apkmirror.com/apk/dj ... droid-apk-download/
Download it on the phone. It will ask you for permission since it is not from Google direct (i.e. classified as unknown). I allowed it and installed it.
2018-6-13
fans877cee42
Flight distance : 689596 ft
Ukraine
I have the same problem +  manual exposure is not correct.
I'v email support and they reply : "I reviewed the manual and specifications of Mavic Pro and what I found out is that the issue was caused by mobile device incompatibility. Apparently, LG G5 is not listed as one of the recommended device for Mavic Pro" -))))))
So i re-installed 4.2.16 and now its ok.
2018-6-14
DRONEST&A
Flight distance : 27493 ft
Brazil
Hi, I'm from Brazil, and here we are having quite a problem with this latest update.
I use a MOTO G5s PLUS - MOTOROLA, before this last update everything was perfect, but now my MAVIC PRO is disconnecting alone.
Any suggestion ?
2018-6-14
3-D
Flight distance : 635764 ft
DRONEST&A Posted at 2018-6-14 06:28
Any suggestion ?
Please check this post.
https://forum.dji.com/forum.php? ... amp;fromuid=1682706
2018-6-14
djiuser_JwYFE3QKythT
Belgium
Same issue here... Samsung s9+. Video 1080p 30fps. Choppy result..
2019-1-6
TVOD
Flight distance : 1680082 ft
With every Go4 update things get worse, the update in November everything was sort of ok, the GPS on the Apple device worked which was the main thing for me, now 3 updates later no GPS on Apple device but apple maps works (I'm not the only one) choppy video now and again,( I'm not the only one) CPU overloaded notice,(Im not the only one) never had this before. I have tried deleting  the app and reinstalling and still the same issues, I wonder if i bought one of the Smart controllers? would that solve my problems?
2019-1-11
aquarius12
Flight distance : 43409 ft
Switzerland
djiuser_JwYFE3QKythT Posted at 1-6 12:41
Similar problem with Xiaomi redme 5 plus.
https://forum.dji.com/thread-175494-1-1.html
Pls. take a look at post #26 and give it a try with other Camera settings. Of couse Video caching is active!
As i said the last Version all worked perfect was 4.2.16.
Nobody can answer me what DJI changed after. First i thought the phone update to oreo 8.1 causes the problem but i never realized that the camera setting could be the cause. Thats why sometimes it was ok and now i know that 30 and 60 fps dont work.
2019-1-12
